December 12, 2014, 04:21 |
workbench flexure bending
sergio
Hi all,
I have a problem with workbench when i want to calculate the stresses in a flexure. The flexure is 7cm long, 2,5cm width and 0.1 mm thick. It is under an angle of 53 degrees with the horizontal axis. on the top right end a force of 0.35N works downwards. The bottom left end is constraint. Structural steel was used and large deflection was turned on. When i try to model this in ansys it gives me a stress of 350MPa working in the material. In my opinion this can't be right since im more than able to just bend the material in real time without it being deformed. Is there anything i am doing worng or forgot to add in my model? I hope someone will be able to help me! Sergio |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
FLUENT installation on UBUNTU 12.04 (LTS) | teymourj | FLUENT | 2 | March 1, 2017 22:24 |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
Question on running CFX simulations in workbench parameter set table | Anna Tian | CFX | 0 | September 20, 2014 01:51 |
Block structured hexagonal mesh vs automated tetra mesh inside Workbench for CFD | Chander | CFX | 3 | November 27, 2011 16:24 |
