Particle Tracking & Free Surface (FLUENT)
Old   March 24, 2015, 06:26
Default Particle Tracking & Free Surface (FLUENT)
Andreas Nikolaou
an1710 is on a distinguished road
I am using FLUENT to simulate open channel flow. The liquid (water) is set under motion by an impeller (paddlewheel), hence I define two cell zones: one zone encloses the impeller and is rotating (sliding mesh) and the remaining computational domain is stationary). My problem is modelled in 2D, assuming periodic boundaries. The free surface between the liquid-phase (water) and the air above, is tracked using VOF and the problem is solved transiently.
After approximately 1200 sec of simulation I inject 1000 inert particles of liquid-water material and use a UDF to track their position over time. The injection takes place in the liquid-phase only. The problem is that a considerable number of particles are passing through the free surface and move upwards from the liquid to the gas phase, which is physically inconsistent.
Any ideas why this is happening? Should massless particles help in solving the problem? Are there any known limitations regarding the use of DPM with periodic boundaries, VOF or sliding meshes?
Needless to say that any suggestion is highly appreciated :-)
Andreas
an1710 is offline   Reply With Quote
dpm vof free surface
Particle tracking with DPM domain & sliding mesh (FLUENT 15.07) CeesH Fluent Multiphase 0 August 8, 2014 10:37
Eulerian particle tracking in fluent asal FLUENT 0 June 17, 2014 05:59
VOF free surface tracking LK FLUENT 2 May 20, 2006 12:20
Particle Tracking...display on a surface Roland FLUENT 2 April 15, 2005 08:31
Particle tracking in Fluent moiami FLUENT 3 November 19, 2002 01:41
