Home > Forums > Software User Forums > ANSYS
how valid are these assumptions to combustor modelling analysis?
Old   April 3, 2015, 14:42
Default how valid are these assumptions to combustor modelling analysis?
zack
zackufairu is on a distinguished road
Hey people!
We are modelling the flow in an annular combustion chamber for a miniature gas turbine.
Being a 10 day (although rigorously studying) newbie to icem I have realised there are some assumptions i must make
1 spark plug is a continous heat souurce rather than time varying
ALSO if not please suggest any alternative which can be steady state.
Like how to model a spark plug.
2 It is technically multiphase flow because fuel entering is atomised
But i want to assume both the incoming air and fuel vapor as gaseous and thus single phase.
The motive then is to calculate velocity at exit.
The time for this project is not much which is why these simplyfying assumptions i felt are needed.
Please suggest any easier alternaties if you feel these assumptions are invalid.
Any cool papers will be appreciated.
zackufairu is offline   Reply With Quote
[ANSYS Meshing] Plugin error no valid bodies found for 2d analysis in part Part mrbrake ANSYS Meshing & Geometry 13 October 27, 2021 11:44
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
The object "ADDITIONAL VARIABLE: alfa" is present in the object "/FLOW:Flow Analysis l.te CFX 4 October 9, 2012 13:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
