orientation of elements influence reaction forces
Old   April 11, 2015, 17:06
Default orientation of elements influence reaction forces
Nederland
roy8888 is on a distinguished road
I use ANSYS 14.5 and i have designed a truss. In the truss i use L-shaped elements. Within ANSYS u can use orientation keypoint to orientate the elements. I know that by default ANSYS uses the element x-axis as the centroid of the element.
Why do my reaction forces change when i change the orientation of the truss when the force on the truss is only own weight. If the centroid of the element is equal to the x-axis, then it should not matter how i orientate my elements. Because ANSYS translates own weight to forces acting on the centroid of the element, or is this not the case...
I know for sure that my line model is 100% symmetric, so that is not the reason.
Does anyone know why my reaction forces change when i change the orientation of the elements?
roy8888 is offline   Reply With Quote
Influence of schemes on mesh size, orientation and type in a convective flow field Tobi OpenFOAM Verification & Validation 8 July 16, 2017 08:01
change in reaction forces when using different element behaviour. roy8888 Structural Mechanics 1 October 10, 2014 03:02
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
