Ansys airfoil meshing problem
Old   August 13, 2015, 02:49
Default Ansys airfoil meshing problem
Salah
Salah87 is on a distinguished road
I'm new to CFD and Ansys.
I've found several tutorials explaining how to generate a mesh for an airfoil in Ansys Meshing. When I tried to do the same I got a different result.
I sliced the field into 4 parts. Then I've applied sizing function on the edges with bias, and mapped face meshing on front surfaces of the domain. The tutorial said It should generate hex domain. Indeed Ansys generated hex domain in three parts, but the fourth was tetrahedral and it was generated with errors.
Thank you in advance for your help
Salah87 is offline   Reply With Quote
[ANSYS Meshing] Problem with ANSYS Meshing - how to refine? pyroknife ANSYS Meshing & Geometry 2 August 22, 2013 13:30
Meshing problem with ansys default mesher wh88 ANSYS 5 October 5, 2011 16:27
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
ANSYS 12.1 2D modelling and meshing problem please help akhenathon FLUENT 3 December 5, 2010 15:55
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 19:24
