Fluid Structure Interaction tutorial
Like Tree4Likes
Old   April 19, 2012, 10:04
Default Fluid Structure Interaction tutorial
Luca
C12Carbon is on a distinguished road
Hi, I hope someone helps me about a couple of things! I'd like to simulate a fluid structure interaction of a deformable body. I want to view how it is deforming under fluid forces and even have an FRF analysis of the body to understand in which cases it has flutter and also know the stress and strain in that cases! Somebody knows some tutorials or a guide that explain the procedure I have to follow? I use complete Ansys 12.1.
Thank you for your attention
Luca
C12Carbon is offline   Reply With Quote
Old   May 30, 2012, 16:43
tmeysam92
tmeysam92 is on a distinguished road
HI Luca,
did you find tutorial?????
I want to work on fsi problem, but i do not have any tutorials
please help me!!!!!!!!!!!!
this is my email:
Tmeysam92@yahoo.com
meysam
tmeysam92 is offline   Reply With Quote
Old   May 30, 2012, 16:52
Luca
Hi meysam! Unfortunately I haven't found any tutorial and nobody answerd me to give me some info about... I hope someone will help me soon because I really don't know I could do it! If you will have some news please let me update about it; I'll do it too
Luca
Old   May 30, 2012, 17:13
Peter Galimutti
p.galimutti is on a distinguished road
Luca
Firstly, is it a 2-way fSI. which means the deformation of solid produces a significant change in flow field or is it a one way fsi? which means the deformation of solid does not produce any significant change in flow field or it can be neglected.
For ansys 12.1 if it is 2-way you need to use cfx or Autodyn.
if it is one way fsi you can use either fluent or cfx.
for 12.1/13.0 versions, you have a tutorial in ansys customer portal titled "Fluid Structure Interaction and Mesh Deformation". The files are located in install die/examples/cfx/valveFSI.pre.
But first you need to go through CFX tutorials if you are not familiar with it.
HTH
muratde likes this.
p.galimutti is offline   Reply With Quote
Old   May 31, 2012, 05:01
Luca
HTH
Well, surely what I want simulate belongs to the on way, infact it produces deformations that could be neglected... it isn't a sail but it looks like a turbine more. Anyway Am I able to do modal analysis using CFX? My first problem is undestand in which case of fluid velocity or pressure I could have flutter on my structure! For example, if you have an airplane wing and if you change inlet air velocity, CFX is able to give me the deformed shape of wing and as and how it moves under that determinate fluid field? If you want to do this "simple" simulation, what do you do?
Thank you for the answer
Luca
Old   May 31, 2012, 14:13
Peter Galimutti
if i have to do wing analysis i'll create a geometry with fluid and solid together.
create a structural component (Static structural) and CFX. Link the setup cell.
in the structural component suppress the fluid part and mesh solid only, and create fluid solid interface.
in the fluid component say CFX, suppress the solid and mesh the fluid region and solve. After that map the fluid loads on the fsi interface already defined in structural component and solve for displacements.
HTH
bhaumikspatel and muratde like this.
Old   June 1, 2012, 07:26
Luca
HTH
Thank you so much for your answer! This kind of process should do in the ANSYS Workbench, in CFX or in other place?
Thank you
Luca
bhaumikspatel likes this.
Old   June 1, 2012, 08:24
Peter Galimutti
The one that I explained is a workbench setting. I would advise you to go through tutorials related to fsi simulation in ansys customer portal.
Old   June 1, 2012, 08:41
Luca
Thank you so much! As soon as I have some news I'll post them!
Old   June 7, 2012, 16:42
Default hi
tmeysam92
Hi C12Carbon,
did you find the tutorial files in customer portal???
I do not have customer portal user name and password.
if you find it , please help me. I need ansys fluent fsi.
tmeysam92@yahoo.com
Old   June 7, 2012, 16:47
tmeysam92
HTH
Hi p.galimutti,
do you have any tutorial about ansys fluent FSi problems.
I do not have username and password for customer portal.
could you please help me.
thanks in advance.
Tmeysam92@yahoo.com
Old   July 21, 2012, 09:05
seyed is on a distinguished road
Originally Posted by tmeysam92 View Post
HI Luca,
this is my email:
Tmeysam92@yahoo.com
meysam
Hi meysam, I have a problem in my FSI analysis, when the run of ANSYS/CFX (in wokbench) starts after a while an error saying "the CFX solver did not produce a results file" appears, whats the problem?
In the "Out File"tab in CFX solver manager the sequence of errors begin from this error:
Error #001100279 has occurred in subroutine ErrAction.
Massage:
CFX encountered the error: Read.Fatal error occurred when requesting Total mesh displacement for interface
please help me.
seyed is offline   Reply With Quote
Old   July 22, 2012, 04:39
tmeysam92
Massage:
please help me.
hi seyed,
i'm really sorry.
i did not work with ansys fsi problem.
in reality i did not find fsi tutorials.
Old   July 23, 2012, 14:35
hi seyed,
i'm really sorry.
thanks alot meysam, I found the solution!!! the time step was 0.1 s (too large) so the answers in ANSYS did not converge, I decreased it to 0.01 s. also the pressure load was large so the displacement in each time step was too large so I decreased it and the problem was solved.
"mokhlesim!!!"
Old   July 23, 2012, 18:22
tmeysam92
"mokhlesim!!!"
hi seyed.
good job!!!!
mohandes mikhastam bebinam, tutorial fsi(fluent+ansys)
nadari????
ansys +cfx manzouram nist.
Old   July 25, 2012, 00:07
tmeysam92
hi All
I'm faced with two warning when open the project.
and then the solid component did not respond and any displacement in result.Untitled.jpg
Old   July 25, 2012, 04:08
hi seyed.
good job!!!!
nadari????
I think there is no way to couple ANSYS with FLUENT, in workbench when you right click on the setup cell of transient-structural there is no way to transfer data to FLUENT.
I have a suggestion!
Go and learn about ANSYS macro...
Old   July 25, 2012, 04:36
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Fluent 2 way FSI
Gweher is offline   Reply With Quote
Old   July 27, 2012, 11:50
Thumbs up
  #19
sumit_raised's Avatar
Sumit Chamling Rai
sumit_raised is on a distinguished road
Send a message via Skype™ to sumit_raised
Luca
Why don't you try the oscillating plate tutorial? It's is present in ANSYS WORKBENCH 13.0 and 12.1 also.
You will find it under help>tutorial>search>oscillating plate.
Its good. I recently finished that involving transient control. If any queries while conducting that, tell me. I will try my level best to sort that.
Sumit Chamling Rai
Mechanical Engineer
NMIT, Bangalore
India
sumit_raised is offline   Reply With Quote
Old   July 31, 2012, 02:42
Originally Posted by Gweher View Post
I'm working with ANSYS 12.1, it seems to be possible to couple ANSYS with FLUENT in ANSYS 14 release.
Fluid structure interaction on baloons vinz OpenFOAM Running, Solving & CFD 38 September 14, 2016 12:38
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 09:30
FSI fluid structure interaction tutorial chapter 23 davedave121 CFX 4 February 5, 2010 01:40
Optimization or fluid structure interaction Steve_NTUA Main CFD Forum 9 August 29, 2006 03:40
Fluid structure interaction tomm FLUENT 2 September 16, 2004 04:33
