having dificulties modeling a turbine blade in Bladegen
Old   December 4, 2015, 10:26
Default having dificulties modeling a turbine blade in Bladegen
Mojtaba Farajpoor
mojtaba.farajpoor is on a distinguished road
Hi
I’m trying to model a Turbocharger turbine blade in Bladegen using a CAD model. I don’t want to import the CAD model into the bladegen.In designing procedure of the turbine blade I need to specify the hub and shroud profile in meridional view and betha angle distribution of hub, Shroud and mid-span. The problem is that I can’t imagine what the meridional view and betha angle are. I know the basic concept of them but I don’t know how to use a CAD model to obtain meridional view and betha angle distribution.
So can anyone please tell me what the meridional view and betha angle are and how I should obtain them in a real cad model?
Any suggestion would be appreciated.
thanks
mojtaba.farajpoor is offline   Reply With Quote
blade angles, bladgen, meridional view, turbine
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 04:09
Rotating turbine blade Pepe26 CFX 7 May 15, 2013 18:18
[ICEM] 3D turbine blade modeling ShaneStan ANSYS Meshing & Geometry 49 December 4, 2011 13:48
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case LittleBart Main CFD Forum 5 January 10, 2011 15:07
