Conduction and Convection Thermal Analysis of a PV Module |
February 19, 2016, 08:26 |
Kevin Williams
Rep Power: 10 |
Hello Everyone,
I have designed a 3D Assembly of a Photovoltaic Module that consists of an encapsulated Silicon cell with a top glass panel and a bottom polymer back sheet. I want to analyze the heat transfer if the module was exposed to a convection from the top and bottom, as well as the heat conduction through different layers in the module. The image shown below is an example of what I have in mind. So I would like some guidance on how to get started. For example: 1. Creating a flow domain with an enclosure or creating a domain in CAD and using the fill feature to assign a fluid material. 2. If I have a certain heat flux, where can I assign it since Fluent has an input of W/m^3. FYI: The given data is: heat flux from the module, air velocity, and ambient temperature. I have done some tutorials, but it's not been very helpful. Appreciate the help. |
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation | Zeppo | OpenFOAM Running, Solving & CFD | 16 | May 18, 2017 18:04 |
thermal conduction and convection in porous media | student2008 | FLUENT | 0 | November 28, 2014 08:57 |
Problem to simulate conduction and convection in the same time in FLUENT | zomayabssa | FLUENT | 0 | March 1, 2014 22:33 |
Convection with Shell Conduction | Corentin | FLUENT | 7 | January 30, 2012 13:12 |
Determine Thermal streeses by CFX module | Riken | CFX | 3 | August 3, 2008 20:58 |
