Piezoelectric modelling in workbench
Old   March 30, 2017, 18:54
Default Piezoelectric modelling in workbench
sadiq
sadiqdr77@gmail.com is on a distinguished road
please I am a student from cranfield university, uk. I am currently doing a project on piezoelectric modelling. I tried using ANSYS workbench to perform the simulation. the project aim is to see the voltage generated by PZT material when it undergoes bending force. the PZT material is attached to a plate made up of steel, I created the geometry and I assigned the steel properties to the first*solid and PZT-5H properties to the second solid. I also also used the PZT extension, applied fixed support boundary condition at end of the geometry and displacement BC to the other end, I applied the voltage boundary condition to the surface and bottom of the PZT. I ran the simulation successfully without any error but the problem I encountered is that*I cannot see the output voltage. when I click on electric results and select the voltage it doesn't appear in the solution. please I need your assistance on how*to tackle the problem. THANK YOU
sadiqdr77@gmail.com is offline   Reply With Quote
Workbench Design Points Update (Parametric Modelling) Andrew Norfolk ANSYS 3 March 31, 2020 05:01
Modelling of a Mixing Tank in Workbench ANSYS 12.1 shadyenany FLUENT 12 June 9, 2017 05:53
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 22:24
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM hjasak OpenFOAM Announcements from Other Sources 2 February 13, 2017 04:59
Remeshing with INTEGRATED Workbench bertozzi_marco CFX 0 December 21, 2014 07:49
