August 18, 2016, 04:19 |
Turbocharger compressor design
Hi everybody,
I've started to test ANSYS workbench to get a feeling about automatic optimization procedure to get the ideal impeller geometry for specific boundary conditions. Iīve found a webinar on ANSYS homepage called "improving turbocharger design" where the author explained a closed loop with Vista CCD-BladeModeler-Vista TF to get a first optimization for given flow conditions. Unfortenualy I struggled to create the same for my own. Two main steps I don't understand and don't let me proceed - every time I connect BM with Vista TF and start the calculating procedure an error message stated that some geometrical parameters missing/canīt use from Vista TF Does anybody know a good documentation that is describing the connection between these two components or describing the needs of TF? - the webinar is showing a closed loop optimization with using a parametric model in BM and DesignExplorer(started at 24:30) Does anybody know how I can implement this parametric model into BM? Do I need the Throughflow component? Do I need I connection to TF to optimize the geometrical parameter to flow parameter? Maybe anybody know a tutorial or similar that's explaining these or a similar optimization procedure. Thanks in advance for your feedback. Michael |
Problem extracting volume in a turbocharger | Jambond | STAR-CCM+ | 54 | January 31, 2017 07:49 |
Meshing issues in Rotor of Turbocharger | Kru | ANSYS Meshing & Geometry | 0 | August 2, 2015 13:09 |
turbocharger | mohi | Main CFD Forum | 0 | January 16, 2015 15:45 |
Custom turbocharger model. | llmbs | Main CFD Forum | 0 | May 1, 2011 04:12 |
Turbocharger simulation | jai | CFX | 1 | April 26, 2011 21:48 |
