SpaceClaim enclosure around surface model (baffles) |
November 1, 2016, 04:50 |
Rep Power: 9 |
Hi!
I can't find how to make an enclosure around an surface model in SpaceClaim. The model is made from surfaces and is supposed to be meshed with ansys and later on transferd to OpenFOAM using fluent3DMeshToFoam. The "enclousre" in SpaceClaim does work perfectly using solids, but this model consists only of zero thickness surfaces (baffles) and it doesnt work at all. Have anyone else experiensed this problem? //jackkra |
December 10, 2016, 03:34 |
Rep Power: 11 |
I have the same problem right now. Did you find a solution? Thanks. |
December 20, 2016, 07:14 |
Rep Power: 9 |
I haven't found any solution to this issue yet. Anyone else? Tscar?
ansys, baffle, enclosure, shell, spaceclaim |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[DesignModeler] what is the rule to choose periodic surface for a single flow passage of turbo model? | shivasluzz | ANSYS Meshing & Geometry | 0 | August 2, 2016 14:55 |
[DesignModeler] Sweeping or surface meshing in enclosure? | Edu-R | ANSYS Meshing & Geometry | 9 | January 23, 2013 13:41 |
Question about the best way to model water jet impingement on a heated surface | Rockda | FLUENT | 2 | February 27, 2011 09:52 |
Surface Tension Force Model | Miguel | CFX | 7 | October 2, 2006 05:30 |
