wear or surface finish analysisi in abrasive flow machining in ansys fluent or CFX
Old   November 17, 2016, 03:45
Default wear or surface finish analysisi in abrasive flow machining in ansys fluent or CFX
doddaswamy v
doddaswamy.1801@gmail.com is on a distinguished road
dear sir, i have a problem regarding how to simulate the wear or material removal anlysis for abrasive flow machining using silicon carbide and polyborosiloxane as a mixture. required results are erosion rate/material removal rate or quality of surface finish and i want to do it for different pipe material, we all know that wear rate or surface finish is different for different materials.please kindly help me regarding this problem i am waiting for your answers..
thank you
DODDASWAMY .V
ASSISTANT PROFESSOR
PESCE MANDYA
doddaswamy.1801@gmail.com is offline   Reply With Quote
surface finish, wear
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Finding node connectivity for a specific surface from Ansys Fluent Tanjina FLUENT 0 April 4, 2015 20:52
Ansys Fluent UDF - for Data Center Air flow management kedarjan Fluent UDF and Scheme Programming 13 November 13, 2013 04:20
Comparison between Solidworks Flow Simulation and Ansys Fluent Bruce828 Main CFD Forum 5 February 23, 2013 10:13
multiphase flow, CFX or FLUENT? luis Main CFD Forum 6 October 5, 2006 13:24
