ANSYS Input/output error on unit = 11. Please check to see if the disk is full. |
November 18, 2016, 13:50 |
Jason
Rep Power: 9 |
I'm running a FSI in ANSYS to import pressure of fluid to solid structure to see the deformation of structure. The solid structural has about 0.5 M elements. The file is in disk D (30GB free space) and my ANSYS is installed in disk C (40GB free space). The solid only has one hyperelastic material. I imported uniaxial test data and curve fit the mooney-rivlin 3 parameter. When I run the simulation, I got following errors and warinngs: 1.Material number 2 ) should normally have at least one MP or one TB type command associated with it. Output of energy by material may not be available 2.Input/output error on unit = 11. Please check to see if the disk is full. 3.Pivoting has been activated for the Sparse Matrix solver. The memory required may greatly exceed the predicted amount. In that event, use the BCSOPTION command to change the memory mode and/or memory size used by the Sparse Matrix solver. The memory currently allocated for the Sparse Matrix solver = 6667 MB. Memory allocated for solver = 10164.501 MB Memory required for in-core = 24807.575 MB Optimal memory required for out-of-core = 7333.694 MB Minimum memory required for out-of-core = 1434.251 MB My questions for those warnings or error 1. I have assigned 1 material to the model. how come it has material 1 and 2? 2. My disks are far away from full. Why does the error shows that the disk is full. 3. I have 32 GB memory. But the warning showing the memory currently allocated for the Sparse Matrix solver = 6667 MB. I don't know why. Also I have run CFD simulation (about 8 M elements) is much large than this problem (0.5M elelments). The CFD simulation didn't have this problem. Thanks. |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Received exception: Disk full or disk related problem | thekay | ANSYS Meshing & Geometry | 4 | June 20, 2010 10:22 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
CFD of tilting disk check valve | Greg Anderson | Main CFD Forum | 1 | July 13, 1999 17:07 |
