Merging facets of STL volume mesh
Old   December 22, 2016, 07:04
Default Merging facets of STL volume mesh
bidi is on a distinguished road
Hello there,
I have written a code to generate an STL file containing volume mesh. Now, I need to specify inlet and outlet boundaries for flow simulation in FLUENT.
As you can see in the attached picture, there are many facets together which express one boundary. In practice, the geometries I am working on have much more facets on one boundary. So, I have to merge all of them together so that I can select a single surface as the inlet/outlet boundary.
I tried to use the Segment/trim surface tool in ICEM with no success. I could use it when I was working on imported STL geometries, but apparently, the tools in the "create/modify surface" section of ICEM are not working with imported STL mesh.
Any ideas on how to form a boundary in STL volume mesh is highly appreciated.
bidi is offline   Reply With Quote
Old   December 23, 2016, 00:46
I read here (Defining boundary conditions STL file) that I should have split the geometry into some pieces to let ICEM create parts. I changed my code in a way to generate each boundary separately. I then imported different parts of the STL volume mesh in ICEM successfully.
Now, how can I use the imported mesh in Fluent? Fluent does not recognise the mesh yet. What steps do I need to take in ICEM?
fluent, icem, stl, volume mesh
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Extracting STL Mesh from STP Volume Kina ANSYS Meshing & Geometry 3 February 6, 2014 00:29
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[Netgen] Volume mesh instead of surface mesh phan OpenFOAM Meshing & Mesh Conversion 4 October 18, 2009 17:17
