Import FSI Solution Files
Old   December 23, 2016, 08:23
Default Import FSI Solution Files
Lucas Ribeiro
Warlord is on a distinguished road
Hello folks,
I am gonna put here the steps to run in batch mode to share the knowledge. I have run a FSI simulation in batch mode with the following commands:
#/bin/bash
nohup /usr/ansys_inc/v171/aisol/.workbench -cmd ansys.services.systemcoupling.exe -inputFile coupling.sci &
sleep 3
_PORT=`cat scServer.scs | grep  -o '[0-9]\+@' | grep -o '[0-9]\+'`
printf "Port is $_PORT\n"
nohup /usr/ansys_inc/v171/ansys/bin/ansys171 -b -i structural.dat -scport $_PORT -schost localhost -scname "Solution" -o ANSYS.out -np 6 &
nohup /usr/ansys_inc/v171/fluent/bin/fluent 3ddp -g -t8  -scname="Solution 1" -schost=localhost -scport=$_PORT -i fluidFlow.jou  > Fluent.out &
After exporting the following files:
coupling.sci, fluidFlow.cas, structural.dat
using respectively System Coupling, Fluent and Mechanical. I have created also the following file (also necessary for fluent):
file/start-transcript "fluidFlow.trn"
file set-batch-options , yes ,
file/read-case/fluidFlow.cas
solve/initialize/initialize-flow
(sc-solve)
wcd FluentRestart.cas.gz
exit
ok
My problem is that I don't know how to read the output files from the workbench environment so that I can check the results. Does anybody know? Is it possible to write a bash script for it?
Obs.: I am using Ansys 17.1
Warlord is offline   Reply With Quote
Old   January 1, 2017, 14:32
Jetteke
Jetteke is on a distinguished road
I'm not sure if this is the official way, but what works for me is importing the results back in the respective solvers in workbench.
Thus, in workbench open mechanical, select solution in the tree, go to tools, and load the result files (file.rxxx)
for fluent, open fluent, go to solution files, recover missing solutions, and import your files, or cfdpost.
Or if you didn't use shell elements in your structural part, you can also view both results at the same time in cfdpost.
If you found another solution, could you post it here?
Jetteke is offline   Reply With Quote
Old   January 18, 2017, 11:35
Lucas Ribeiro
Unfortunately I could not find another way, being different then the one you said. And when I try to use the "recover missing solutions" approach, I simply cannot put all the files at once. VERY FRUSTRATING!
fsi, import, solution, workbench ansys 17
Unsteady simulation solution files in parallel gunnersnroses SU2 1 December 15, 2015 13:28
CFX 2-way FSI solution PranjalNewton CFX 3 October 27, 2015 14:44
HELP! FSI Tutorial Files! Mudassir ANSYS 0 April 20, 2014 13:27
May I import the definition or result files of CFX Hao FLUENT 0 November 26, 2008 04:12
Import of gambit db files worth Siemens 2 September 24, 2004 05:52
