February 9, 2017, 04:14 |
Low Fan Flowrate on Icepak
Fatih
Hi, i am modeling a flow where an axial fan(internal) suck the air from open ended channels(fins) at Icepak. Volumetric flowrate data i found from the analysis are less than the experimental ones(which i am sure that experimental data are correct). I tryied zero equation, enhanced two eq. and enhanced RNG. Mesh along the channels and fan are good enough. I meshed using y+ = 5. Even in enhanced two eq. and enhanced RNG flow values are a way less than the actual one. pressure discretization scheme is second order, others are first and i also updated the fan cure wrt. altitude. And energy equation is not solved since, i think it is not necessary. Is there anything that I can do as an improvement
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
Trouble modelling a jet fan | josee | OpenFOAM Pre-Processing | 0 | September 23, 2016 13:06 |
Obtaining Static Fan Pressure in Icepak | robojames | ANSYS | 1 | October 13, 2015 08:02 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
