February 23, 2017, 00:00 |
Inflation/Prism layer for rough surface
Dhairyasheel deshmukh
Rep Power: 9 |
I am studying the effect of surface roughness on a performance of centrifugal pump using Ansys. I have used inflation layer in meshing to capture boundary layer near the blade. the height of inflation layer is approx. 1mm. I want to know that can I go with the same inflation layer for all simulations with different values of roughness or I have to change it? If so how to relate the height of inflation layer to the mean grain size(0-1.25mm for my case) of wall roughness. thank You, Regards, |
[ANSYS Meshing] Seperated two surface inflation mesh ( boundary layer) | Onurozcan | ANSYS Meshing & Geometry | 2 | December 10, 2015 08:01 |
Seperated tow surface inflation mesh ( boundary layer) | Onurozcan | Main CFD Forum | 4 | November 29, 2015 05:32 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
[snappyHexMesh] Snap Precision to a STL Surface | malaboss | OpenFOAM Meshing & Mesh Conversion | 16 | July 26, 2013 01:44 |
