May 12, 2017, 11:14 |
INISTATE, initial stress
NA
Hi All,
I am trying to analyze the deformation of a structure under residual stress of the top layer. I am using static model. I dont want to apply any external force load to my structure except for the residual stress of the top layer. I know using INSTATE command (workbench 18) I can define the initial stress. But, I am not sure how to use the command. Should I insert this command under the static structure and then read the command under the solution? Thanks |
inistate, initial stress |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
