September 19, 2017, 09:21 |
Problem with Design-modeler and ICEPAK
I have two problems to resolve: 1- I create a geometry with Design-modeler. To import it in Icepak, i must simplify the geometry on different levels ( 0 --> 2). However, the number of solids are higher and the simplify not work (because the initial geometry contain different blocks). This implies a blocking of the design modeler. I attached a picture of the geometry. --> So how I can simplify this geometry with design modeler ? 2- I can use the simplification level 3 (cad geometry) with design modeler. However, the problem arises with ICEPAK because cad geometry don't allow to create a mesh. --> have an idea to mesh complex geometry CAD with Icepak? Thank you for you response. |
parametric study with design modeler and icepak | aminem | ANSYS | 3 | May 21, 2014 05:11 |
