Centrifugal pump Simulation in Cfx ; Head capacity curve not matching
Old   December 6, 2017, 22:01
Default Centrifugal pump Simulation in Cfx ; Head capacity curve not matching
Dileep S
dileeps is on a distinguished road
I am trying to simulate a centrifugal pump to generate head capacity curve and compare it with experimental results. My simulation results of head values much differ from the test data.
Pump specs:
Duty point discharge - 2 litres per second
Head- 21 m
Speed-2800 rpm
Impeller dia - 141 mm
Cfd gives much higher values of head in higher flows.
This pump is supposed to give 0 m head at around 3.5 lps flow, but instead gives about 19 metres of head.
I used SST & K-E models, used wall roughness, but not much advantage. Hope anyone may help me resolve this issue.
dileeps is offline   Reply With Quote
Centrifugal Pump Simulation Problem! warex FloEFD, FloWorks & FloTHERM 29 September 23, 2014 10:27
CFX Pre Domains for centrifugal pump MechKim CFX 1 September 24, 2012 08:06
Centrifugal Pump simulation for radial forces tareqkh FLUENT 0 February 11, 2012 08:31
centrifugal pump calculation using cfx sandy CFX 10 July 19, 2007 04:08
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
