fluent Solution
Old   December 11, 2017, 09:42
Thumbs up fluent Solution
Ishan Sharma
ishaniis is on a distinguished road
I am currently doing a project whereupon
I need to develop a vaporizer whose
Pipe
OD - 30mm
ID - 28mm
t = 1mm
Pressure(Inlet) = 3.5 Pa
Pressure (Outlet) = 1.5 Pa
Mass flow rate = 3g/sec = 0.003 kg/sec
Inlet Conditions (Fluid) - 25 degree celsius
Outlet Conditions (Fluid) - 95 degree celsius
L (Pipe)= 450mm
I have calculated the Q for the given problem by the formula
Q = m. Cp . (dT)
Correspondingly, Heat Flux by (Q/A)
I want to simulate it for a pipe which will be provided heating by wounding Nichrome wire as a Heat source, the entering fluid must vaporize at the outlet of the pipe section
Now ,
Q1. I am little confused to keep the wall boundary conditions
as -
Constant Heat flux
or
Constant Wall Temperature
or
Convection.
Q2. Can I find out the percentage of fluid which is converted into vapour form?
ishaniis is offline   Reply With Quote
ansys 14.0, fluent
Water-Salt Solution - FLUENT CSolarFD FLUENT 6 July 31, 2017 08:58
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 0 June 22, 2016 08:26
Exporting fluent solution Je5u5 FLUENT 0 June 7, 2016 05:07
Turning off equations during solution in CFX, like fluent. adilsyyed CFX 3 April 27, 2015 03:57
One-way FSI... can I start with structure and then transfer solution to Fluent YANNAPOL FLUENT 1 April 1, 2015 15:52
