December 11, 2017, 09:42 |
fluent Solution
Ishan Sharma
I am currently doing a project whereupon
I need to develop a vaporizer whose Pipe OD - 30mm ID - 28mm t = 1mm Pressure(Inlet) = 3.5 Pa Pressure (Outlet) = 1.5 Pa Mass flow rate = 3g/sec = 0.003 kg/sec Inlet Conditions (Fluid) - 25 degree celsius Outlet Conditions (Fluid) - 95 degree celsius L (Pipe)= 450mm I have calculated the Q for the given problem by the formula Q = m. Cp . (dT) Correspondingly, Heat Flux by (Q/A) I want to simulate it for a pipe which will be provided heating by wounding Nichrome wire as a Heat source, the entering fluid must vaporize at the outlet of the pipe section Now , Q1. I am little confused to keep the wall boundary conditions as - Constant Heat flux or Constant Wall Temperature or Convection. Q2. Can I find out the percentage of fluid which is converted into vapour form? |
ansys 14.0, fluent |
Water-Salt Solution - FLUENT | CSolarFD | FLUENT | 6 | July 31, 2017 08:58 |
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli | mmkkeshavarzi | FLUENT | 0 | June 22, 2016 08:26 |
Exporting fluent solution | Je5u5 | FLUENT | 0 | June 7, 2016 05:07 |
Turning off equations during solution in CFX, like fluent. | adilsyyed | CFX | 3 | April 27, 2015 03:57 |
One-way FSI... can I start with structure and then transfer solution to Fluent | YANNAPOL | FLUENT | 1 | April 1, 2015 15:52 |
