Fluid Flow Distribution
Old   March 18, 2018, 20:58
Default Fluid Flow Distribution
D.R
Dave
D.R is on a distinguished road
Hi, Guys! Can anyone help me with fluid flow distribution in ANSYS Fluent? I have one Inlet and two outlets manifold (picture is attached). The velocity is 26 m/s at Inlet with gauge pressure 7 bar. So I provided in Boundary Conditions, Inlet Velocity V = 26 m/s and at outlet 1 and 2, outflow = 1.
I have run the analysis. I have velocity, stream line, vectors results in Post Processing. But I am not sure how to determine whether the fluid is distributed equally to both outlet 1 and 2? I mean - Using which function in Fluent, it can be found? Secondly, Are my Boundary conditions good enough to get this either equal or non-equal fluid flow distribution through manifold pipe? Your response will be highly appreciated! Thank you!
D.R is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
[OpenFOAM] How to calculate the fluid flow through a surface lynx ParaView 4 January 20, 2016 11:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
