Near wall treatments
Old   May 16, 2018, 08:28
Default Near wall treatments
Pierrm is on a distinguished road
Hello there,
I modeled a pump on CFX (and FLUENT) with the SST K-omega model. This model combines the k-epsilon formulation for the free Stream and the k-omega formulation in the boundary layer.
To use k-omega formulation, "the first computational cell must have its centroid in y+ ~1". That means a fine mesh allows the resolution of the boundary layer.
And if the y+ is in the log-layer (30-200), wall functions are used.
But what is happening if we use Automatic wall treatment?
And if the y+ is between 1-30 (in the Buffer layer)?
Thank you all in advance
Pierrm is offline   Reply With Quote
Old   May 20, 2018, 04:24
Lucky
There is a blending function that blends the log-layer formula to linear-layer one. When you are in the buffer layer, the same blended formula is used so nothing changes.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
What's the problem with turbulence models near the wall region? Jaydi_21 Main CFD Forum 6 July 7, 2017 03:39
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Near Wall treatments in openfoam with refined mesh spwater OpenFOAM 3 June 1, 2015 06:34
