Installation of Ansys 19 on Ubuntu 18.4
Like Tree5Likes
  • 1 Post By victor pira
  • 4 Post By ztnuaa
Old   June 15, 2018, 10:00
Default Installation of Ansys 19 on Ubuntu 18.4
victor pira is on a distinguished road
I am trying to intsall ANSYS 19 on Ubuntu 18.4. I have followed the brilliant installation guide here but sadly some issues persisted. Namely:
- The installation wizard freezes at ca. 93%, the last action being "Created service script: arcnode". When it is shut down manually, it does not provide any error log and ANSYS is still executable but one does not know whether the installation was truly succesful.
- The Design Modeler is unable to be opened by the Workbench.
Tested solutions:
- I have installed all the packages recommended in the link above.
- I have tried to execute the .../runwb2 -oglmesa
- I have tried LD_LIBRARY_PATH=/ansys_inc/v190/Framework/bin/Linux64/Mesa
tubulence-IO likes this.
victor pira is offline   Reply With Quote
Old   August 9, 2018, 07:45
Default Same problem
rweber is on a distinguished road
I have the same issue, could you find any solution?
rweber is offline   Reply With Quote
Old   August 10, 2018, 13:14
Landy
lycastrog is on a distinguished road
I have the same issue, could you find any solution? Please anyone...
lycastrog is offline   Reply With Quote
Old   August 13, 2018, 02:50
buck2202 is on a distinguished road
I just spent a limited amount of time trying to debug this after a clean install of Mint 19 (based on ubuntu 18.04)--the INSTALL script does accepts a -debug flag, but the point where the installer hangs is still fairly opaque.
FWIW, things fell apart for me in script
ansys_inc/v162/commonfiles/configs/linx64/config/AnsConfigWB.sh
at the first execution of line 265
$WB_INSTALL_DIR/.workbench -cmd $exeFile -RegServer
The first successful execution would report
RegSvr32: DllRegisterServer in /usr/ansys_inc/v162/aisol/dll/linx64/libans.common.clrhostmonou.so succeeded.
but mine would just sit there forever. I'm guessing the problem stems from Ansys's integration mess with Mono.
At that point, I reinstalled ubuntu 16.04 in a virtualbox instance, installed ansys there, tar'd up the whole directory, moved it to my 18.04 installation, and extracted it. I'm able to launch fluent without issue, which luckily is all I care about right now. Workbench in v162 depends on libpng12 which is not in ubuntu 18.04's repos, but maybe you'll have better luck with 19. I'm stuck with 16 because the behavior of my UDF code mysteriously changes at v17+
buck2202 is offline   Reply With Quote
Old   August 18, 2018, 01:23
Timo ZHANG
ztnuaa is on a distinguished road
Dear Fellows:
I just upgraded my Ubuntu 16.04 to 18.04 yesterday. And I have ansys 19.1 installed in 16.04. Fluent and ICEM works fine in 16.04.
But in 18.04, ICEM can't start. the error message is:
ICEM_ACN is "/home/zt/software/ansys_inc/v191/icemcfd/linux64_amd".
ANSYSLIC_DIR is set to /home/zt/software/ansys_inc/shared_files/licensing
LD_LIBRARY_PATH is "/home/zt/software/ansys_inc/v191/icemcfd/linux64_amd/lib:/usr/local/tecplot/360ex_2017r2/bin:/usr/local/tecplot/360ex_2017r2/bin/sys:/usr/local/lib::/home/zt/software/ansys_inc/v191/icemcfd/linux64_amd/bin:/home/zt/software/ansys_inc/v191/icemcfd/linux64_amd/dif/iges:/home/zt/software/ansys_inc/v191/icemcfd/linux64_amd/../../Framework/bin/Linux64".
args =
[1] 16983 segmentation fault (core dumped) /home/zt/software/ansys_inc/v191/icemcfd/linux64_amd/bin/icemcfd
When i reinstalled ansys 19.1, I got stuck at 89%. Then I forced to shutdown the installer. ICEM still gives the same segmentation fault error.
And i think this error is not something like the "segmentation violation error" which need xfonts-75dpi and xfonts-100dpi to be installed.
I tried :
1.export LD_LIBRARY_PATH=/ansys_inc/v190/Framework/bin/Linux64/Mesa (because i messed up some mesa libraries when i upgrade my system)
2.upgrade mesa to the lateset using ppa
3.checked arguments available in the icemcfd script, all of them didn't work
Did you guys have the problem with icemcfd?
Thank you for helping!
Regards
ztnuaa is offline   Reply With Quote
Old   August 31, 2018, 00:51
Timo ZHANG
I solved the problem with ICEMCFD a few days ago.
I check the start script file of icemcfd at "ansys_inc/v191/icemcfd/linux64_amd/bin"
There are two solutions:
Solution 1. If you don't want to change the icemcfd start script, just run the following comman:
icemcfd -log tmp.log
-log is a icemcfd argument, tmp.log is the log file generated at your pwd.
Solution2. If you use other argument when you start icemcfd, the following solution may be not very good. (I don't use arguments when start icemcfd, so it works well for me)
First- cd to your icemcfd bin dir:
cd /usr/ansys_inc/v191/icemcfd/linux64_amd/bin
Then: edit the icemcfd by any text editor you want, here we use gvim:
gvim icemcfd
change line 607:
       eval "$ICEM_ACN/bin/med" "$args"
to:
 "$ICEM_ACN/bin/med" $args
This may cause a error message when icemcfd started:"Unknown filetype", just ignore it.
or without $args
 "$ICEM_ACN/bin/med"
I think it's caused by a bug of "eval" shell command at ubuntu 18.04.
Hope this solution can help
Old   October 24, 2018, 04:52
ANV
Amey Vasulkar
ANV is on a distinguished road
Were you able to figure out the integration with mono issue?
Thanks,
Amey
ANV is offline   Reply With Quote
Old   April 25, 2019, 05:51
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Originally Posted by ztnuaa View Post
gvim icemcfd
change line 607:
to:
or without $args
 "$ICEM_ACN/bin/med"
What's it got to do with the problem in the first message? The freezing while installing Ansys?
Any solutions to this?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   April 25, 2019, 06:08
Timo ZHANG
Hi Mojtaba,
Sorry, I don't know. Since I only use ICEM and Fluent. This problem doen't bother me.
FYI, I also installed Ansys in a workstation running CentOS6.9. The installation freezing problem didn't show up.
ztnuaa
Old   October 3, 2019, 10:30
ginggs is on a distinguished road
There was a bug (LP: #1739505) in csh in Ubuntu 18.04, but it has been fixed now.
ginggs is offline   Reply With Quote
ansys 19, ubuntu 18
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 03:17
[OpenFOAM.org] OpenFOAM 2.40 installation on Ubuntu 12.04 LTS eddykendo OpenFOAM Installation 1 July 18, 2015 17:38
Ansys CFX and Fluent on UBUNTU OS sunilpatil CFX 4 May 2, 2015 06:52
Ansys CFX support for ubuntu LUIS1717 CFX 0 May 17, 2014 15:07
ansys 13 installation shishir14 ANSYS 4 January 22, 2013 00:27
