June 21, 2018, 05:59 |
Air water mixing
Sibtain
I am a student and working on tap aerators, can you tell me please which module on ansys 18 can mix these two fluids and how?
Thnkyou |
June 26, 2018, 13:06 |
M
Rep Power: 12 |
So, the first question is rather easy: there are two cfd solvers, which are CFX and Fluent. Both are able to perform multiphase calculations.
The second one however, is not easily answered. You need to build a simulation model which involves meshing, setting boundary conditions and other stuff. This part usually needs some expertise and will not be easy to achieve without prior knowledge. |
Mass Transfer Between AIR and WATER | Math13570 | CFX | 12 | June 29, 2016 08:14 |
Is it possible to integrate air through a system with mixture of air and water? | Hale | OpenFOAM Post-Processing | 1 | September 30, 2013 08:57 |
Mixing water and air | miroslavgojic | ANSYS | 2 | January 25, 2012 00:49 |
Boiling of water with hot air | Dr. Flow Squad | CFX | 2 | July 27, 2009 07:37 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
