Fluent: Proper Solver for Pressure ratio in high pressure turbine
Old   September 20, 2018, 02:00
Default Fluent: Proper Solver for Pressure ratio in high pressure turbine
BB
lotd is on a distinguished road
I have to calculate pressure ratio of high pressure turbine. Turbine is a part of jet engine.
I have doubts if it is possible to count that in fluent because I'm not sure if Fluent can solve case when the stream should move rotor blades.
I have data like:
- pressure before turbine
- mass flow rate
- blades rotation speed
In my case I set:
- pressure-based, Steady
- K-epsilon, Realizable, Enchanted Wall Function
- moving frame with rotation-Axis Direction (1,0,0) and Rotation speed 870 [rad/s]
- BCs: pressure-inlet, pressure-outlet, rotation vector of walls (1,0,0), periodicity
- Scheme: Coupled, Gradient: G-G Node Based, Pressure: Standard, Momentum & Energy: Second Order Upwind, Turbulence Kinetic Energy & Turbulence Dissipation Rate: Power Law
I would like to ask You if that settings are correct. What's more I would like to know if should add rotation speed -870, because I know this is how it should be done with compressors.
I am looking forward to hearing from You,
Lotd
lotd is offline   Reply With Quote
fluent, frame, moving, rotation, turbine
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Simulating movement of air from low to high pressure in Fluent jwillie2000 FLUENT 0 April 11, 2013 04:18
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 04:13
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
