How to make periodic condition between two surface in two parallel pipes
Old   October 31, 2018, 03:27
Default How to make periodic condition between two surface in two parallel pipes
Ahmed Awwad
Ahmed A. Serageldin is on a distinguished road
My case is modeling fluid flow and heat transfer through U-tube pipe, and I want to simplify it by making periodic condition between the outlet of right pipe and inlet of the second pipe as shown in the attached figure.
I used tetrahedral surface mesh element and sweep method.
Should I define the periodic condition in meshing or in Fluent? and how to do it?
Ahmed A. Serageldin is offline   Reply With Quote
Old   October 31, 2018, 03:45
Andrea
Andrea1984 is on a distinguished road
Hi Ahmed,
I think you are looking for the mesh/modify-zone/make-periodic command in the Fluent TUI. You will have to specify the IDs of the two boundaries that you want to make periodic and that you want to impose a translational (or rotational) periodicity. Once periodicity is imposed between the two boundaries you can use the Periodic Conditions tab to include additional features (such as an imposed pressure drop/mass flow rate).
Andrea
Andrea1984 is offline   Reply With Quote
Old   October 31, 2018, 04:18
Ahmed Awwad
Originally Posted by Andrea1984 View Post
Hi Ahmed,
Andrea
Thank you for the quick reply, but when I do this it gives me an error that the two surfaces are not matched.
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Parallel computation using periodic boundary conditions AEMD SU2 2 March 26, 2014 23:41
[ICEM] Periodic condition on effusion cooling model BahaZero ANSYS Meshing & Geometry 0 July 15, 2013 15:51
[swak4Foam] some errors in compiling groovyBC in OF220 immortality OpenFOAM Community Contributions 10 April 1, 2013 03:46
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 11:51
