January 10, 2019, 18:48 |
Electric arc simulation in Fluent?
vektor
Rep Power: 7 |
I know it has been done "somehow" i read the paper 'Evolution simulation of lightning dischargebased on a magnetohydrodynamics method' and they used ansys fluent to simulate a high current electric arc.
i am trying to do the same thing, i got the material properties, the MHD_module, everything seemed to be right, untill i realized that the MHD_module in fluent wouldn't allow for an electric current density as an input, the only option is to solve for magnetic field somewhere else and input in as B0. the problem is, the magnetic field depends on: TIME- no problem here. but it also depend on the electric current density, which in term depends on the electrical conductivity of the air, and the electric conductivity of the air in the other hand depends on the Temperature, so in short, the magnetic field is coupled with both heat transfer equations and time. |
[Other] Change the mesh in mixerVesselAMI2D tutorial | hoemmaria | OpenFOAM Meshing & Mesh Conversion | 2 | October 6, 2017 07:43 |
Fuel Spray Simulation - How to go about it using fluent? | hadiniesta | FLUENT | 2 | May 26, 2017 02:12 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
[blockMesh] multiregion mesh with blockMesh | alvora | OpenFOAM Meshing & Mesh Conversion | 44 | July 21, 2013 14:14 |
