ANSYS Optimization failing to update Results component.
Old   January 22, 2018, 07:28
Angry ANSYS Optimization failing to update Results component.
Harry Molloy
harmollo1 is on a distinguished road
Hello all,
I am running a MOGA optimization in Anysy DesignXplorer as part of my final year project. Unfortunately I have ran into a reoccurring problem that seems to have no solutions online. As well as this, I have looked in the DesignXplorer manual for a solution but found none.
I am running an optimization through Fluent and everything works fine in the test run and the solution looks okay. However once I begin the optimization I run into trouble, the optimization cycles through each component and then solves the case but it appears to become stuck on "Updating results component in direct optimization". At this point the results component also show a "refresh required" symbol. As well as this, when the error occurs the optimization can not be aborted and ANSYS must be force closed as it becomes unresponsive.
This is a huge problem for me in my project and particularly annoying as I can find no info about it online and also because the simulation itself runs okay, trouble only arises when it is being optimized. I have tried to alter license settings and CFD-post properties to update with design points but nothing works! Hope for anyone to be able to help me or give advice about this problem.
harmollo1 is offline   Reply With Quote
Old   March 21, 2019, 15:30
David
dchen is on a distinguished road
Hi there, I am having the exact same problem as stated above. Just wondering if you have found the cause of the issue and if you would mind sharing it with me. thank you
dchen is offline   Reply With Quote
cfd post, designxplorer, optimization, results
Clear results in Ansys CFX JohMey CFX 4 December 2, 2019 11:29
ERROR: Update failed for the Setup component in Fluid Flow (CFX). amsys Main CFD Forum 0 June 13, 2016 10:53
FLUENT results to ANSYS Jin Yan FLUENT 2 April 28, 2011 11:22
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
Exporting temperature results fro fluent to Ansys vinay kulkarni FLUENT 1 February 21, 2007 03:31
