Rep Power: 6 ![]() |
I have a question. I wrote an Expression massFlowAve(Pressure)@Inlet in CFX-Pre. How can I monitor this Expression during the solving process? Thank you very much for your answer. Best Regards |
M
Rep Power: 10 ![]() |
Open the CFX Solver-Manager tool. If your simulation is still runing use the 2nd of the buttons in the toolbar to monitor a run in progress. Navigate to your simulation folder (where the file "mon" is located in) select the folder and hit open. Then u can see everything just like for a concluded run. The solver manager even updates the data while it is written from the CFX solver itself.
Thank you for your answer. I don't know exactly what you mean. During the Run I see this window. Now I don't want to see the Graphs of the Residuals, I want to see the graph of my Expression during the run. How can I moitor it?
M
Normally, there is a tab called "User Points" next to the "Wall and Boundary Scale" one. If its not there, in the top menu go to "Monitor" -> "User Points" and hit it. Then the tab should be visible.
Per default, it will show all the monitor points you have. By making a right click anywhere in the plot region you can change the Monitor Properties like which line(s) you see and the axes. |
When I click on Monitor, I don't have "User Points"? Is this not part of the Student Version? I hardly believe that.
M
AFAIK the student version is identical to the commercial version but has a limit of 500k mesh nodes.
Can you make a right-mouse button click next to the boundary and wall scale tab and "create monitor"? |
Joe
Rep Power: 0 ![]() |
How much cost commercial and where i can buy it?
CFX basic version around 35.000€ or so.
I found out how to do the mointor point so thank you very much guys. ![]() |
Display Modes | |
HELP PLEASE! CFX Solver run ended abruptly due to power blackout | RobBanks | CFX | 10 | May 19, 2016 12:43 |
Setting Up and Monitoring Transient CFX Simulation | Jack001 | CFX | 3 | April 30, 2016 09:44 |
Error reading profile data in expression in cfx post | banu | CFX | 4 | March 27, 2015 09:03 |
Creating Expression in CFX | SHIKHA BHUYAN | CFX | 3 | September 24, 2014 03:49 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
