Changing heat source in ANSYS
Old   October 20, 2019, 09:52
Default Changing heat source in ANSYS
jnow is on a distinguished road
Dear Colleagues,
I have got a little problem which I hope you could help with.
I would like to use heat source which is decreasing in time period (e.g. 18MW in 1 sec, 15 MW in 2 sec, etc.). It's decay heat from low-power nuclear reactor, geometry at this moment is not so important, I will just use simple geometry in 2D.
Is it possible to solve this issue in ANSYS? Does anybody know how to do it?
Thank you in advance for your help.
jnow is offline   Reply With Quote
Old   October 21, 2019, 00:37
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello. I believe You can use "expression" as an input (I don't have time to confirm it right now). Here is an expression I was using for varying inlet temperature. I think You can modify in for Your purpose:
300[K] + if(t>6300[s],0[K],if(t>5400[s],600[K],if(t>4500[s],0[K],if(t>3600[s],600[K],if(t>2700[s],0[K],if(t>1800[s],600[K],if(t>900[s],0[K],600[K])))))
Best regards,
Sheaker
sheaker is offline   Reply With Quote
Heat source on the surface of the wall Vishsel OpenFOAM Running, Solving & CFD 2 April 27, 2020 09:59
Creating a heat source on ANSYS workbench chris92jc ANSYS 1 August 6, 2015 03:10
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
