How to create a body from a point cloud boundary |
December 6, 2019, 17:17 |
Rep Power: 13 |
I have been trying to do this for quite a while and it seems so basic but I cannot get SpaceClaim or DesignModeler to do this. I have a point cloud that represents the wall in a fluid domain. I have another point cloud that represents the inlet for that same domain. I need to import these into one of the geometry applications and get the points into the form of surfaces. So I tried importing a point file into design modeler but that didn't work out because I would have to make Polylines and then loft them together. Then I tried to export the two boundaries in the form of STL files which contain the surfaces as triangulated bodies (many triangles make up each surface). From inside SpaceClaim I tried to Merge Faces to get rid of the small triangles from the STL file but it won't let me merge them all. I can merge down to about 3 large faces and then I get the "Unable to Merge" message. Does anyone know of any way to get a collection of points into a single surface that bounds a fluid body? I can write the points as a text file or STL file if needed. Here is a video showing what I am doing. I have two STL files, which I import into SpaceClaim. I want the larger one to be a wall, and the circular one to be the inlet for analysis. You can see I import them and at the end select many of the smaller faces to merge and they merge just fine. But I cannot merge all of them like I need to because of some SpaceClaim bug that will let me merge all of the triangles down until I have only a few large faces but I cannot merge the large faces into one. https://www.youtube.com/watch?v=UjNb...ature=youtu.be Thanks |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
