June 13, 2020, 08:16 |
Using processors of many computers
Ahmed
Rep Power: 6 |
Due to Corona matters , I can't go to the university to use the CFD Lab and now I am doing a simulation of a transient case which will take a lot of time if done using cores of one computer
so I have 2 computers and 1 laptop Is there a way to connect them together to use all of their processors ? If yes How I would do that in terms of Hardware connections and software connections? thanks |
June 14, 2020, 09:11 |
Rep Power: 11 |
AFAIK you can get benefits from many computers only if you use a high speed connection like InfiniBand. If you use regular Ethernet then connection between computers will become bottleneck and computational speed may even decrease compared to a single machine.
June 14, 2020, 09:48 |
M
Rep Power: 12 |
Second that. Without high-end connection between the units your additional resources will be eaten by the needed communication being to slow. Also I can imagine the cores with the least speed and RAM will just slow down all the others. I bet the overall performance will be worse compared to one computer.
July 25, 2020, 11:21 |
#4 | |
ikslein
alpha.water field zero for parallel run with particular number of processors | VKr | OpenFOAM Running, Solving & CFD | 1 | August 30, 2022 05:12 |
Simulation crashes when using high amount of processors | Za-ck | OpenFOAM Running, Solving & CFD | 3 | April 7, 2022 04:57 |
Get list of shared points by neighbor processors with same order | andpush | OpenFOAM Programming & Development | 0 | June 18, 2019 04:19 |
Socket 2011-3 processors - an overwiew | flotus1 | Hardware | 10 | June 17, 2017 09:47 |
64-bit processors for home computing | Ananda Himansu | Main CFD Forum | 2 | March 16, 2004 12:48 |
