Stent Crimping in ANSYS
Old   August 13, 2014, 16:56
Default Stent Crimping in ANSYS
rsbabu2 is on a distinguished road
I am trying to simulate the ‘crimping’ of a certain geometry which can be considered as an elementary part of a cardiac stent. The geometry is basically a ring with a uniform cross section – the outer surface of this geometry falls on the surface of a cylinder. I am applying the load as a pressure on the outer surface. What I expect is the entire ring to be compressed / ‘crimped’ to a smaller radius due to the external pressure. But when I run the simulation, the entire geometry seems to translate and move sideways. Can you tell me what I am doing wrong?
See attached for files and results screenshots.
Also here: http://files.engineering.com/getfile...ping_files.zip
rsbabu2 is offline   Reply With Quote
Old   August 20, 2014, 09:31
Issue resolved.
Old   November 17, 2020, 16:13
Unhappy project
Youssef
youssefkrayem is on a distinguished road
hi, i'm trying to do the same simulation on the same type of stent, does it bother you to send me your project ? it's for a university project.
youssefkrayem is offline   Reply With Quote
ansys, crimp, deformation, stent, stress
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
[ICEM] Aneurysm + Stent Meshing ! rjd150 ANSYS Meshing & Geometry 5 May 11, 2016 12:21
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
Ansys HPC licensing policy assafwei ANSYS 0 June 29, 2014 16:00
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
