2 element airfoil structured mesh and blocking technique
Old   June 6, 2021, 09:25
Default 2 element airfoil structured mesh and blocking technique
Beer1_0 is on a distinguished road
Hi all, I have meshed this airfoil with a slotted flap in ICEM CFD. It is my first attempt on 2 element airfoils and I would like your comments and suggestions to improve it.
I began with making a c grid around the main airfoil and then split the blocks around it. Then I took one of the block in the wake region and converted into c grid around the slotted flap using the o grid tool.
Beer1_0 is offline   Reply With Quote
Old   March 7, 2022, 17:16
jose daniel
hoyos98 is on a distinguished road
I suggest you visit https://aeroptimal.com/mesh (you must create an account to use this module), where you can create a full structured airfoil mesh - https://youtu.be/4Opu0zk7gFk . You can export .su2 .msh .foam .vtk
hoyos98 is offline   Reply With Quote
hexa blocking, icem 16, structure mesh
[ICEM] Blocking strategy for a Multi Element Airfoil (ICEM) mix ANSYS Meshing & Geometry 16 January 17, 2016 13:41
[ICEM] Blocking issues with structured mesh RagingPotato ANSYS Meshing & Geometry 13 October 13, 2014 07:51
ICEM Internal wall structured mesh blocking costy ANSYS Meshing & Geometry 13 March 11, 2014 02:45
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
