SpaceClaim Geometry Combine of Multiple Untouching Solids |
April 14, 2022, 11:19 |
Moe
Rep Power: 4 |
In Spaceclaim, I am trying to combine solids that are intended to be one domain, but they are not in contact with each other. Like Trees, so each tree is in a separate location, and I want to merge them in SpaceClaim so that I will have only one domain in Fluent and Only one wall interface in the boundary conditions. I used to create the geometry in Autodesk inventor which allow this feature, and then export STEP and import to Ansys. But now I'm forced to use Spaceclaim because I have imported Geometry from OSM and its the only way I can turn it to soilds in spacecalim. But spaceclaim does not accept to combine solids that are not in contact with each other. Is there any way around? I hope someone can help. Thanks Last edited by shadymody; April 14, 2022 at 13:19. |
April 15, 2022, 02:24 |
Gert-Jan
Rep Power: 27 |
You need to check if they have overlap,
If so, then remove the overlapping regions. Then you have to go to menu Workbench and use the Share Topology. If everything goes well, then the mesher will see only 1 surface in between the solids that allows for interface definition in Fluent |
ansys, fluent, geometry, inventor, space claim |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
how to combine multiple block files in ICEM? | kpv | CFX | 3 | December 13, 2007 08:12 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Multiple import of Geometry in GAMBIT(Catcon Simu) | Amod kumar | FLUENT | 0 | July 21, 2006 23:55 |
Virtual/Real geometry. | Jack Keays | FLUENT | 9 | June 15, 2000 23:39 |
