electromechanical modal matrices of PZT actuator
Old   August 21, 2022, 16:15
Default electromechanical modal matrices of PZT actuator
md salem
md_salem is on a distinguished road
I have coupled field structural system (cantilever substrate plate equipped with two piezoelectric patches, one of them is actuator at the root of cantilever and the other is sensor at the tip of the cantilever).
I need to extract the modal matrices of such system:
mass matrix of the system
mechanical stiffness matrix
piezoelectric coupling matrix for each of the patches
Knowing that I do such analysis using Workbench 2022R1
Can any one help me with such problem ?
md_salem is offline   Reply With Quote
modal analysis, piezoelectric, piezoelectric coupling, stiffness matrix
Discrete adjoint cannot be run in parallel if variable load actuator disc model used FabianBueeler SU2 Shape Design 1 June 23, 2023 15:56
Plasma Actuator Modeling mahdihasan Main CFD Forum 1 July 27, 2019 01:35
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
Actuator Line Method mspranavmn Main CFD Forum 0 September 6, 2018 10:30
Actuator Line Model mspranavmn ANSYS 0 September 5, 2018 17:33
