Surface points not converging
Old   March 30, 2023, 22:20
Default Surface points not converging
Chris
mechEnginerd is on a distinguished road
Hey everyone,
looking for some input here. I'm doing a steady state natural convection problem on a PCB in Icepak.
PCB in a thin wall enclosure. Top and bottom of cabinet are wall and the sides are all vents.
Mesh quality looks good. Face alignment and skewness is 1 (it's a simple block model).
Applied a small upward velocity to get it going. Residuals seem to converge ok, but my surface monitor is not...It ramps up, levels off briefly, and then just keeps climbing. Residuals are set to E-4 and they converge at around the 100th iteration.
mechEnginerd is offline   Reply With Quote
sHM doesn't add layers to any surface Vinzmann Mesh Generation & Pre-Processing 0 March 23, 2021 05:02
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
