urgent help, bad convergence
Old   August 31, 2021, 01:18
Default urgent help, bad convergence
Jesus Silva
Jesus Silva is on a distinguished road
Good morning everyone, how are you?
I need urgent help for my project at the university
I am analyzing a centrifugal fan (I think everything is fine) but at the time of simulation I do not have good convergence.
not down from e-03
I need help to know what to do attached I send you images of the fan, if someone can download the model and help me.
If I have to pay for an advisory, please tell me, it is urgent for my project at the university
what I want to do is analyze the pressure at the fan outlet
to perform flow vs pressure
Thank you very much everyone for your attention, in the link you can download the model
https://drive.google.com/file/d/10_K...ew?usp=sharing
Jesus Silva is offline   Reply With Quote
Old   September 29, 2021, 14:01
Chrowale
mluckyw is on a distinguished road
from what I can see from the MAX residual and RMS residual that the bad convergence is localized as the MAX is 10^2 times higher than the RMS. You need to know where is the location of these elements.
One way to do it is (that I know of):
- Run the same CFX run with the CFX-Pre setup of Output control -> Output equation residuals and select all.
- Open CFX-post then create volume -> isovolume -> your residuals desired -> above value.
- Do some refining or coarsen the mesh in those region.
Or alternatively use the high order turbulence numeric at CFX-pre solver control and set it to high resolution if available
mluckyw is offline   Reply With Quote
Old   March 15, 2023, 05:57
Daniel
zacko is on a distinguished road
Can you post your .Out File directly here? Then, we can analyse you boundary conditions and see whether something is missing or maybe wrong... The complete 1GB file is not necessary in my opinion
zacko is offline   Reply With Quote
ansys, cfd - post, cfx & fluent, converge error, convergence problem
Bad convergence perfermance of boiling heat transfer in chiller(plate HEx) shanheplus FLUENT 10 April 23, 2020 14:37
Continuity Convergence Problem in CFX cfd seeker CFX 2 July 2, 2015 11:12
CFX overwhelming Fluent in mass convergence of boundary layer separation case Pierre1 FLUENT 7 March 26, 2015 21:43
Tutorial on Fluidized Bed has convergence issues luca.delbene STAR-CCM+ 0 December 2, 2014 06:05
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
