March 29, 2023, 23:22 |
Flow field is not conformal, how to fix it?
XiaoS
Rep Power: 3 |
Hey everyone,
As the fig.1 shows, there is a obvious boundary in the flow field. Fig.2 is the mesh I used. They are two bodies but they are conformal actually. I wonder how to make Fluent recognize them as a whole without merging them in DesignModeler. Thanks a lot in advance SongX |
March 30, 2023, 15:38 |
Erik
Rep Power: 23 |
In Design Modeler, select all bodies, right click, and "create part". This multibody part will share nodes on the interfaces, acting as one meshed body.
Without doing this it just meshes the three bodies as completely separate bodies, and if you click on a line or face, there will be two lines or faces there, one for each body. If you create part, there will only be a single line or face in between the parts, not two. |
March 30, 2023, 21:10 |
#3 | |
XiaoS
Rep Power: 3 |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
OF v2006 overset tutorial: position of pressure reference changes flow field | tecmul | OpenFOAM Running, Solving & CFD | 0 | January 24, 2021 10:00 |
What is a fluctuation in flow field and how to generate fluctuation in flow field? | ht2017 | Main CFD Forum | 2 | November 3, 2020 20:41 |
rerun with same flow field, different fluid props | Tim | Phoenics | 0 | March 3, 2004 14:51 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
