July 22, 2023, 04:42 |
Velocity Inlet angle
Rep Power: 8 |
I am trying to model a conical velocity profile as shown in the image attached. The flow enters the computational domain from a surface that lies in the XZ plane. The half cone angle is 30 degrees and the flow velocity magnitude is 45 m/s. The steady-state simulation is done in Ansys Fluent. In order to model this scenario, what should be X, Y, and Z components in the velocity inlet boundary condition? Any recommendation is much appreciated. |
ansys fluent, velocity profile 3d |
Specifying a prescribed velocity inlet | SadBoySquad | OpenFOAM | 20 | February 9, 2022 06:40 |
Problem with velocity inlet using FireFoam | Jean_S | OpenFOAM | 0 | July 5, 2021 04:40 |
Setting angle of inlet velocity. | kareemm2 | OpenFOAM Pre-Processing | 7 | April 15, 2016 05:22 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
