Creating a bounded plane surface in newer versions of Fluent
Like Tree1Likes
  • 1 Post By marshallmccray
Old   January 22, 2024, 15:03
Default Creating a bounded plane surface in newer versions of Fluent
Marshall McCray
marshallmccray is on a distinguished road
How do you create a surface of finite length and width (a rectangle) in Fluent 23R2? In older versions you could create a plane with the “bounded” option, but that option does not exist now.
Update: Ten seconds after posting I figured it out. Create a plane surface and in the “method” drop down, use “three points” and below there is the bounded option. It creates a rectangle.
annathree likes this.
marshallmccray is offline   Reply With Quote
Using a Plane id in Fluent UDF cdf_user Fluent UDF and Scheme Programming 13 October 17, 2023 00:06
Error in gmshToFoam on ESI v2106 siefer92 OpenFOAM Programming & Development 4 July 17, 2021 05:11
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 18:28
Newer fluent versions - problem with postprocessing destroy FLUENT 1 June 2, 2020 05:58
Create a curved surface/ plane in fluent ? tarkesdora FLUENT 1 September 15, 2014 14:04
