Creating a bounded plane surface in newer versions of Fluent |
January 22, 2024, 15:03 |
Marshall McCray
Rep Power: 3 |
How do you create a surface of finite length and width (a rectangle) in Fluent 23R2? In older versions you could create a plane with the “bounded” option, but that option does not exist now.
Update: Ten seconds after posting I figured it out. Create a plane surface and in the “method” drop down, use “three points” and below there is the bounded option. It creates a rectangle. |
Using a Plane id in Fluent UDF | cdf_user | Fluent UDF and Scheme Programming | 13 | October 17, 2023 00:06 |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 05:11 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Newer fluent versions - problem with postprocessing | destroy | FLUENT | 1 | June 2, 2020 05:58 |
Create a curved surface/ plane in fluent ? | tarkesdora | FLUENT | 1 | September 15, 2014 14:04 |
