Parameters and Fluent in Ansys 12
Old   March 26, 2010, 19:53
Default Parameters and Fluent in Ansys 12
Edu
Edu-R is on a distinguished road
Hi all!
I´m doing a rear wing with the new Ansys 12, and I need to simulate some variations of the flap (angle of attack and it´s position from the main airfoil).
I put these values as parameters in the modeler, and now I would like to know if I can automate the simulations and get the Cl and Cd of each simulation. I want to do a table with all the combinations and their respective Cl and Cd to choose most optimized version.
The dimensions are defined as Input Parameters. ¿How can I define an output parameter?
Thanks in advance!
Regards:
-Edu-
Edu-R is offline   Reply With Quote
Old   March 29, 2010, 15:43
Edu
Has somebody an idea?
Old   October 21, 2010, 12:13
Jade M is on a distinguished road
In CFD-Post, click on Expressions tab, right click on the expression and select Use as Workbench Output Parameter.
Jade M is offline   Reply With Quote
Old   October 24, 2010, 12:51
Edu
Hi Jade!
Thanks for your answer, but I did it some months ago, and it worked perfectly.
Regards:
-Edu-
Old   March 21, 2014, 10:57
Chandrasekhar
chandrasekhar is on a distinguished road
Hi
i would like to change the boundary condition (i.e the heat flux at a wall) by 50 units each time and run the case till it converges. right now i am using the modification tool in fluent but i would like to know how to write it as a parameter and use it to define the boundary condition at the wall. Any help on this would be appreciated. Many thanks for replying.
with regards
chandrasekhar is offline   Reply With Quote
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 6, 2018 23:37
Reverse rate parameters with CHEMKIN imports Kevin L FLUENT 1 June 27, 2013 04:22
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
Fluent parameters for sailing yacht analysis Daniel FLUENT 0 April 24, 2007 06:47
Some nondimensinal Parameters American Larki FLUENT 0 December 21, 2002 18:39
