Incorrect Drag Coefficients
Old   March 31, 2011, 07:04
Default Incorrect Drag Coefficients
William Nicholson
w-nicholson is on a distinguished road
I'm a third year MechEng student and I'm having difficulties with some CFD analysis.
I am currently meshing an aerofoil in ICEM, and modelling in CFX at various angles of attack.
My lift coefficients are coming out with errors between 3% and 10%, which I'm ok with.
My drag coefficients however are producing errors between 55% and 80%, which is obviously not good.
So far I've tried re-fining my mesh, playing with the surface roughness of the aerofoil, trying different turbulence models.
I have attached a few of screenshots of my mesh, however I'm quite confident its alright because of my correct lift coefficients.
Any help would be greatly appreciated.
Thanks
Will
w-nicholson is offline   Reply With Quote
Old   March 31, 2011, 07:27
William Nicholson
Apologies for the double post, the forum said the first post didnt work.
Can I delete one of them?
Old   July 8, 2011, 12:31
Wantami Puntea
Wantami is on a distinguished road
I have the same problem too.however in drag coefficient ,you'll try to use only pressure drag (not total drag ). In my view CFD can predict viscous force better than measurement which is usually hard to estimation, then CFD give the high value than experimental value in low angle of attack range.
hope this help
Wantami is offline   Reply With Quote
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 18:31
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Final Year Project - CFD on Drag coefficients jamesho123 Main CFD Forum 1 September 15, 2009 21:50
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 14:45
pressure. lift and drag coefficients waqar mahboob Main CFD Forum 0 July 25, 1998 03:34
