Fernando
Rep Power: 15 ![]() |
Hi, I'm trying to study the aerodynamics of a wing, and for that I have created a mesh made of 4 zones (this is because I want a very precise control of the mesh). Once the mesh is done and with high quality I entered it in fluent.
The problem is that once in, the contact walls between the 4 bodies are recognized as walls and not as fluid. I don't know how to change this and I need some help. Any idea?? Thank you very much |
Fernando
The thing is that I'm using a sweep method mesh, and before doing that there were 4 sewpable bodies, and after doing that just one.
ok, if you have only 4 bodies and is not an annoyance to connect the faces manually, you can connect adjacent faces using a mesh interface instead of a multibody part.
See "Using non-conformal mesh" tutorial (Fluent help) for more info |
Fernando
I tried creating a part from the 4 volumes and also I named the hole stuff. The thing is that, before doing this, there were 4 sweepable volumes, and before doing it there was only one, so I couldn't mesh the geometry as I wanted. How can I avoid this from happening?
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 10:40 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 01:10 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
