problem in simulating porous drying process
Old   December 7, 2011, 06:29
Exclamation problem in simulating porous drying process
benson621 is on a distinguished road
i am using fluent to simulate a air drying process of a piece of cotton.
i have tried to simulate the whole setup with a fan a some volume of area.
but my computer is too slow to calculate that huge amount of meshes.
so i decided to remove the large volume of air and the inlet, with only a thin layer of air, setting the air to be a constant high temperature, simulating the constant hot air flow around the cotton.
the water can be vaporized and come out to the thin layer of air, but now the problem is, the vapor accumulate in the layer of air. (i have tried pressure-oultet for the surface of the layer of air, but the rate of vaporizing water still slow down at the early state, so i think it fails)
in real case, the vapor should be carried away almost immediately by the air flow.
can it possible to set the condition as the vapor come out of the cotton, it disappear? or how can i set the vapor to get out of the air much faster?
thank you for paying attention to my problem.
and sorry for my poor english
benson621 is offline   Reply With Quote
Old   December 8, 2011, 11:54
do anyone know please tell me please.
thank you so much!!!
Old   December 13, 2011, 03:57
David Abrantes
Bubble O is on a distinguished road
Hi benson 621,
A couple of months ago I had to deal with an evaporation problem. But it was ink printed on web. Could you send me your fluent file so that I can have a look at your problem?
my email: davidmanuel1201@hotmail.com
Do not give up. Fluent is like women
Bubble O is offline   Reply With Quote
Old   December 13, 2011, 05:33
Originally Posted by Bubble O View Post
Hi benson 621,
thank you for your response.
i am new in ansys fluent.
which part of the file you need, i think it is not possible to send you the whole project file, right?
should i save as some specific format, so that it is small but contain enough data for you to go through my case ?
Old   December 13, 2011, 05:56
David Abrantes
Just send me the files you need to run the model on fluent.
Old   December 13, 2011, 11:37
i have already sent to your email (davidmanuel1201@hotmail.com),
can u receive it? coz my email seems to have some problem, i am not sure if the email was sent out or not actually
Old   December 13, 2011, 11:42
David Abrantes
I got it. I will check it soon.. keep in touch
Old   December 16, 2011, 14:59
can u figure out how u make it ?
Problem in defining porous region on an imported tetrahedral mesh run_cfd OpenFOAM Pre-Processing 0 May 24, 2011 02:15
Porous media solving problem mulfal OpenFOAM Running, Solving & CFD 2 June 23, 2010 05:31
problem about droplets in porous cck Siemens 0 August 6, 2005 00:48
Modeling drying in porous media Oliver Main CFD Forum 0 January 14, 2005 11:41
POROUS SURFACE MESHING PROBLEM subramani.j Siemens 1 March 3, 2004 04:45
