Home > Forums > Software User Forums > ANSYS
Meshing suggestion for a newbie!
Old   March 6, 2012, 07:19
Default Meshing suggestion for a newbie!
chandu143 is on a distinguished road
Hi, for past few days I have been doing analysis of 3D slider bearings which look something like this in fluent using workbench 12.1.
Firstly I did analysis on plane slider bearings which was easy for somebody new to ansys mesh like me and results were in tune with standard results. The mesh method I used was automatic with edge sizing and mapped face meshes and the results were good quad meshes.
But when I started doing my actual model which is a slider bearing with a rectangular surface texture on fixed plane, the automatic method no longer gave
me better mesh . So I changed to multizone meshing it is working for some shapes(different textures), but when I change any dimensions of texture the same method which I applied previously would not work . I still can't figure out how to mesh these surfaces so that i can get a uniform mesh like the one without textured surface.Any suggestions would be of great help!
P.S.
the image i provided is just to give an idea the actual clearance between the moving and fixed surface is in microns for my problem which I guess is what not allowing me to mesh correctly
chandu143 is offline   Reply With Quote
Old   March 10, 2012, 12:26
I figured it out anyway if anyone had same problem I would be more than happy to share my experience just message me.
[ICEM] Hexa meshing of Wind Turbine blade. Help for Newbie please federvo.mala ANSYS Meshing & Geometry 4 June 8, 2013 03:19
Newbie to OpenFoam - meshing questions monti OpenFOAM 2 January 3, 2011 10:07
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
