March 31, 2013, 12:24 |
Gravitational pull simulation
Hello!
Is Autodesk Simulation CFD 2013 capable of computing parameters of fluid flow, based only on gravitational pull? So far, after reading ton of manuals, reviewed numerous internet presentations, and conducted few simulations I have come to conclusion that it can’t. The only computation based on gravity is calculation of flow parameters based on heating. Am I correct? My goal is to find not too complex software for simulation of water flow through small hydroelectric plant, so my only input data is gross height of water. Everything else should be computed, flow, velocities, pressure....etc. |
April 8, 2013, 10:12 |
Mark Decker
Rep Power: 13 |
Looks like 2014 is adding free-surface capability which may help if you are looking at open channel flow.
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 03:36 |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
Axial fan simulation in UG/NX 7.5 | fan123 | Main CFD Forum | 2 | April 23, 2011 08:22 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
